Can I convert 1973 7.5 to a 9.8?
huntin dawg
According to my shop manual the only difference between a 1973 7.5 HP and 9.8 HP is the type of carb they have. Breaking that down further the difference I see is the main jet size. It's .035 for the 7.5 and .047 for the 9.8.
Can I convert it to a 9.8 simply by changing the jet to a .047?
Thanks,
HD
Faztbullet
Re: Can I convert 1973 7.5 to a 9.8?
Nope ..You need the KB11A carb body as venturi and pullover is different.
Downwindtracker2
I don't know what a pullover is,either,but I have read the porting is different.
Chinewalker
You need more than the carb to convert them - the cylinder blocks are different. The 7.5 block is marked "COMET" on it, which denotes smaller porting. They use the same block casting but they're machined differently. Not sure if it holds for all 7.5/9.8s for all years, but the ones I've seen have definitely had smaller ports on the 7.5...
huntin dawg
Now that makes sense.
I'd still like to know what pullover is.
HD
