Re: Can I cut GPS antenna cable ext???
Of course you can splice the cable. I would cut it near the connector that feeds into the GPS display. Fwiw, not all GPS antennas come with connectors installed. Some ship with bare wires at the display end so you can attach the connector appropriate for your display. Depending on how smart the antenna is you may have several (maybe 7) wires as Juneau points out. If you can get a replacement connector/plug for your GPS display that is the way to do it. Otherwise you will be making a splice. If splicing, I suggest soldering the conductors and using adhesive-lined heat shrink (see the 3M product called EPS-300). Also, you can take this opportunity to shorten the antenna cable if you need to.<br /><br />Offset the splices:<br /><br />--------[splice]--------------------------<br />---------------------[splice]-------------<br />--------[splice]--------------------------<br />---------------------[splice]-------------<br /><br />Use a larger diameter of adhesive-lined heat shrink to enclose the whole spliced area. That 3M product has a 3-to-1 shrink ratio.
<br /><br /><br />If you have a dumb GPS antenna, you will be cutting a single coax cable as JB mentioned. I wouldnt splice it. I would just cut off the old connector, route the antenna cable, cut off the excess cable, then install a new coax connector. Installing a coax connector is really easy. It is important to be sure you make a good connection with the internal shielding conductor. The shielding conductor is probably aluminum foil wrapped around the dielectric (foam-like insulator). Or it could be braided wire, or both foil and braid if it is high quality coax. Whatever coax connector you use (crimp or compression), I suggest putting a piece of that adhesive-lined heat shrink over the cable and new connector to make a water-tight seal.<br /><br />Good luck.
