Can I decarb in a barrel?
John Lapic
I have read many posts about decarbing with Seafoam. The instructions include running a gallon of mixed gas with 3/4 can of Seafoam at WOT. If I remove the prop, can I do the same in a barrel? My logic is I need to get the RPM's up and if I remove the prop, I should be able to accomplish that in a barrel. I will need to make sure I keep a good water flow to avoid overheating. What do you think? I have a Johnson 9.5.
rjezuit
Re: Can I decarb in a barrel?
DO NOT run a 2 cycle engine unloaded!!! This can result in a run away condition and bad things can happen, like destruction. Run in a barrel with the propeller spinning and in gear if you must, but it is best to run it on a boat if possible. Rick
iwombat
You can do a decent decarb in a barrel running at about 1/3 throttle with the prop on. Even the 1/3 throttle isn't really necessary, but don't push it past that or runaway is very likely.
John Lapic
Thanks for the tip. I can run it on the lake but thought I could save some time by doing the same in a barrel. I"ll save smoking out the neighbors and take it to the lake.
tmcalavy
Yeah, at least at the lake if someone objects you can point to the smoke drifting off and say "it was that guy that just went around the bend" then talk a lot about fogging for skeeters.
