can I deglaze
firebird
Is there any way to deglaze cylinder wall with out removing pistons? Thank you for your help
samo_ott
Re: can I deglaze
removing and deglazing is the only way I know. I guess you could try emery cloth when each piston is at BDC. Others should have a better idea though.
jimmbo
Re: can I deglaze
Why do you want to deglaze the cylinders without having replaced the rings?
firebird
Re: can I deglaze
I did a comp test got 71-75 psi on all cylinders thought it was low so pulled off head to check and found cyl.wall smooth as glass and a lot of oil in the intake ports. checked bore size within specs. engine starts idles and runs good (all though I think it should do better thr rpms are low ,talked to previous owner to find he always used to much oil didn,t think it would hurt .plan on draining tanks and cleaning and fresh proper mix and I was hoping if I could deglaze it would bring comp. up Trying to save the money on a rebuild for now. By the way the engine is a 1989 Johnson (looper) 200 hp GT. Thank you for your imput
samo_ott
Re: can I deglaze
I've had success deglazing before without changing the rings. If they've still got sharp edges. Albeit on small 2 cyl engines though, not sure about the big ones. and I removed them and did it properly.
BillP
Re: can I deglaze
Maybe it needs to be decarbonized to let the rings float better. You can't always see what's hiding. I'd try that before honing.
firebird
Re: can I deglaze
appreciate the advice not sure what to do don,t think de-carb will help. will I hurt anything by deglazing cylinder?Thought of doing so with piston at bdc any advice is helpful by the way love this forum thanks alot for your time and effort
wbeaton
Re: can I deglaze
Don't do it without removing the pistons. You need to use a hone to get the proper cross hatch and even removal. With the pistons in place you can't get the very bottom of the cylinder wall. Also, you don't want all that crap falling into your rings and getting stuck in there. Either try a decarb or take it apart and do it properly.
