Can I get a weight estimate?
gfh110
The trials continue to get this boat I bought from Brooklyn to Pennsylvania in one piece. I acquired a dual axle trailer in decent condition (new tires at least!) from a guy in Maryland and I'm currently working on retrofitting it to fit my boat. (Rebuilding the bunks, repacking bearings, installing lights, and flushing the brakes among other things.)
I plan on completely stripping everything out of this boat that isn't fastened down before I tow it home. With a 5.7 Mercruiser inboard that I'm estimating at about 900# (according to the Merc website, rounding up), can someone give me a rough idea how much this thing weighs? I'd call the marina, but they'd probably charge me a hundred bucks for an "educated guess."
It's from 1973, 26' long, about 11' at its widest, empty gas tanks, no batteries or anything, just a large, empty boat and motor. For lack of any good overall pictures, it's pretty much identical to this (minus furnishings & canopy):
http://www.yachtworld.com/boats/1441330/0
Your assistance is greatly appreciated.
-Jerry
watermellonI
Re: Can I get a weight estimate?
NADA usually lists dry weight, not sure if they go back that far though.
I'll Guess it to be around 6000/ 7000lbs......
You Do realize that you can NOT just load that thing up,+ head down the road with it don't you,..??..??
Federal Law is that the Maximun Width on a hyway is 8'6"....
And,...
From Brookyn to the NJ stateline you're only allow a Maximun width of 8'......
You'll need Permits,+ probably a chasecar to Safely,+ Legally move it.....
dcg9381
If you can't move it yourself, there's a site online that allows people to bid on transportation of items.
I'd guess around 6-7.5k myself, maybe a little more. I've got a 23' 454 powered "sport boat" - not nearly as much hull or fiberglass, larger motor - it weighs 6200 on a trailer.
I tow it with a 5.4L, 4wd, extended cab F-150, 4 wheel disk. I really should be towing it with a 3/4 ton truck.
Silvertip
What size tires does this trailer have? I'm guesing here but I suspect you need at least a tri-axle trailer for that load.
