Can I hook up two fuse panel together?
Gradywhite3535
Would I be able to hook up both of these two fuse panels together or use both of them somehow? Or would I just have to buy a bigger one?
NYBo
Re: Can I hook up two fuse panel together?
I only see one fuse panel.:confused:
NYBo
BTW, yes, you can use more than one fuse panel if you wish.
Thalasso
Get another one and make sure it's wired correctly and the hot wire is large enough for the load. Why is the ground wire hooked to the red wire?
Then you have two hots on one fuse?
Marine Fuse Blocks - Right here on i-boats. Marinerated
NYBo
To amend me previous reply: Yes you can use that fuse block plus another, but I wouldn't bother in this case. The one in the picture is no prize, and I would go with Thalasso's advice.
Don S
Didn't we get your wiring figured out in your previous 10 or so threads and many PM's about it, along with the new wiring diagram I made for you and said you were going to use?
Gradywhite3535
Yeah we did but as we all know money doesn't grow on trees and i was just asking a question. Thanks everyone for the help.
NYBo
As a "frugal boater" (read: cheapskate), I can sympathize. What does the other fuse panel look like? If you don't have one yet, it should be only a few dollars more to get one with 4 additional circuits to replace the one in your picture.
