Cougar_15
- Aug 11, 2008
- 93
I am ready to reconnect the cap to the hull and I'm having a bit of a dilemma, the manufacture used rivets to make the connection but I'm having a hard time figuring out what size rivets to get. I'm pretty sure that the diameter is 3/16 but the length varies quite a bit depending on where you take the measurement. The spot where the cap overlaps the hull does not lay flush most of the way around, there is a gap between the two... The rub rail also has a lot of areas that have gaps. I'm not even sure if a rivet will hold correctly across a gap...?
So my question is would it be possible to use screws to connect the cap instead of rivets? For the bow there is no access to the inside so it would just have to be screws but the rest of the way around there is access to both sides so I was thinking SS bolts with locking nuts? Or maybe a combination of rivets where the connection is flush and screws where it's not? Would this work or am I asking for trouble?
A little background, my boat is a 15' tri-hull that will be trailed and garage kept and used exclusively on inland lakes.
