Can I use an AGM battery charger for GEL battery?
I just got a Renogy 100ah Hybrid Gel Battery. I already have an older battery charger that I purchased a few years ago, it's a Schumacher Speed Charge 10amp charger with STD and AGM settings, and it has a microprocessor controller and auto voltage detection.
I know you are not supposed to charge/maintain Deep Cycle marine batteries with a standard automotive charger, but do I need a GEL specific charger or is the AGM setting okay to use with GEL batteries, or do I still risk overcharging and ruining my battery even using AGM setting?
I've tried to find the answer through the google machine but everything I see is the usual "dont use STD chargers on AGM batteries", but have yet to find anything that talks about using or not using AGM on GEL.
Thanks in advance!
GreatVegetable
