Can I use slightly longer push rods than stock on 454 Gen V?
Status
Not open for further replies.
CLi87
So I had several bent push rods due to seized valves so I bought a full set on ebay that supposedly came from an 89 454, which should be the exact same push rod as the part #'s are the same for the push rods between the 89 454 and my 93 454 Gen V, but upon examination both the intake and exhaust push rods are just a tiny bit longer than what I have, my intake push rod is 8 3/16" and the one I got is 8 4/16", same with the exhaust, mine is 9 3/16" and the ones I got were 9 4/16". Do you guys think it would still be ok to use these or will I have running problems?
alldodge
Under normal conditions, of a hydraulic lifter, a 1/6 variation is not an issue. The lifter them selves have more lee way then a 1/16
GM part numbers are not the same for the Mark IV motor and the Gen V motor
go to NAPA, get the right push rods
CLi87
Are they not the same part #?
That's the parts diagram for my Gen V by serial # and it shows part #75589 and #75590
Parts diagram for an 89 Gen IV also shows the same part #'s for the push rods. However when I lookup the specs on the push rods it shows that the measurements on mine were correct and the ones I got were wrong by 1/16".
No, they are not the same part number
your motor is a GM 454 Mark IV. push rod diameter is 3/8" length is 9.252 and 8.280"
the Gen V uses 5/16" diameter and 7.850 and 8.873
the Gen VI uses different length. 8.569 and 7.592 " https://www.chevrolet.com/performance-parts/components/engine/big-block/pushrods
CLi87
1965-1990 is Mark IV
1991-1995 is Gen V
1996-2000 is Gen VI
2001-2008+ is Gen VII
Crate motor 454's 502's are Gen VI
Scott06
Wait my motor is a Gen IV? I thought 93's were Gen V? and I have the flat torque rockers, no adjustment nut, I thought that was a Gen V feature?
Motor year and boat year are two different things
snowbrd84
Status
