I have bought an 98`150 Ocean Pro where the VRO pump was disassembled when I bought it. The problem is that I can not see how the fitting on the fuel outlet shall fit into the bracket. It is turned 90? compared to the fitting on my 94`175. On the BRP parts list, it should be the same fuel fitting on these two models.
Maybe this pump came from another motor? Does anyone know if it is the same pump on these models? I realize that they have different partsnumbers; 0435555 on the 94` 175 hp, 0438400 on the 98`150. There is a big number "3" on both of them. Does this indicate it is the same pump, or does this number mean something else?
The most important issue is wheter I can use the pump from the 94`175 on the 98`150?
