can inflate my sib with compressor
slate1234
Hi all is it possable to blow up my sib useing my compressor if so what adapters would i need??
Sea Rider
Re: can inflate my sib with compressor
Which sib boat model is it and type of compressor to start with ?
Happy Boating
Peter_C
I use my home compressor for pumping up my boat at home, but it isn't quite portable. I just use an air gun with a larger tip on the end, and the same adapter that my double action pump uses.
Sometimes I use a scuba tank, but it isn't much different than my home compressor, except it is portable and more often than not there is more than one in the boat. .
slate1234
I have a 3meter bombard with a wont run 7.5hp mercury, I have a stanley compressor i use for work (I am a joiner) Peter how did you adapt the fitting to fit your air gun?
Thanks for the replys Paul
