Re: Can Lower Unit Be Left Drained?
Harris, every spring we boat mechanics get at least one of you guys in the shop, and we laugh our butts off.....for your knowledge, a lower unit empty of gear lube [and fill screws back in the holes] will make approximately 1/4 mile out of the harbor under full throttle before eating itself....if you leave the screws out, you can get a full 1/2 mile out before failure, because of the cooling effects of the water inside the case.....you can surely guess why I am so knowledgeable of this subject, and in every instance the owner had the best intentions.....fill it up, just so if you forget to have it fixed, no one can call you a dumba$$!
