Can not ID prop
trent1030
Hello
Just bought a 1981 Bayline Capri.w/ a Volvo Penta AQ125A with a Volvo Penta 270 outdrive. The prop is very banged up. The best I can tell it is 14"-14.5". It is a three blade Alum and a 17 spline.Inside the hub it does have Michigan and 0 8 2 0 3 1 . It does look like it has the rubber shock core. Also something I have not seen looking around for this, is that it has slots cast into it at the end. It looks like they are there to use a gear puller if it was to stick on the spline. Have not run engine yet so I do ne know rotation. I also have no clue of pitch. I was on this sight and could not identify it, when I picked 1981 it did not give me the option for Volvo Penta, just OMC, or Merc. Also I have not seen a similar parts break down. Everything I have seen or read, says there would be more parts. I just had the cone nut, the allen that holds that on. The prop, then behind the prop was a plastic washer or slinger. The outdrive shaft comes out through a very nice contoured pieace. I see no bearing or grease very clean design. Any help would be helpful.
Thank you
