I replaced my idle port exhaust boot and upon removal of the old one I found two pieces of black plastic tubes which looks like the one on the pic. It looks like it inserts to some kind of port but don't know which one. The engine has been running fine except for rough idling when in the water. It idles fine when on flushing device but as soon as it gets into the water the idling RPM goes down from 1000 RPM to 700 RPM in neutral. When in forward gear it goes down to 500 RPM. I saw the old boot leaking exhaust and concluded this could be the cause. So I replaced the boot and found this two plastic tubes inside the leg's exhaust. I have to test the engine on the water with the new boot. I'll post back but for now I want to have an idea where these two tubes go to. Thanks.
