Re: can somebody recommend a good I/O Mechanic around central NJ?
After all of the trouble you have had with the clicking noise ( I looked up your previous posts) it seems to me like you have a bad starter. Does it even sound like the starter is running? If the solenoid on the starter has gone bad then the motor may run but it just does not throw out the gear to engage the flywheel. Only real way to tell is to remove the starter, which I know you have asked for advice on. If you are having trouble finding a reputable marine dealer why don't you try an auto mechanic to remove the starter and get it tested. Whatever you do though DO NOT get it replaced with an equivalent car starter. That would be dangerous, as they are not spark isolated. The procedure however for removing/replacing is exactly the same as on a car engine. I just did a friends bayliner on Tuesday which had the exact same symptoms. I think was a couple of years newer than yours and it was not difficult to replace except for the tight squeeze to get to it.<br />Good luck!
