Can someone give me some info on a 25 hp evinrude?
nola mike
In the market for a small ob/boat. Came across the following. I know nothing about the motor (and very little about o/b's in general), could someone give me a little info as far as vintage (looks late 70's?), reliability, trouble spots, parts availability, etc? thanks!
coolbri70
Re: Can someone give me some info on a 25 hp evinrude?
the cowl looks like my 85 hp and its a 79' 008.jpg parts are available
jbjennings
The only negatives is that it doesn't have shallow drive or through-hub exhaust, or a propshaft hp rating, which are all 3 not that big of a deal. Otherwise that's one of the most reliable 25hp outboards there is. Run it before you buy it. The clutch dogs on those seem to go bad after 20 or 30 years. :)
Great motors, easy to work on.
JBJ
jimmbo
It does have a shallow drive. a little lever that hides on the midsection, starboard side. you flip it down and it will rest on the trim adjustment pin
Mi duckdown
Nola. Price? In MI. 100 150 bucks Max.
Home Cookin'
$300-500 here if it's running well; it's a very popular size--practically speaking it's the biggest almost portable pull start motor
