can someone help with oday sprite
cjones4438
i am needing some closer pics or anything to help understand whats if anything is missing, and how things should be done to set the boat up. minus the jib sail it is not here but apperantly the boat id made to sail with or without?
tpenfield
Re: can someone help with oday sprite
You can Google that under images . . . lots of images come up.
Many sail makers could make you a new jib. All boats can sail without the jib.
cjones4438
thank you. i have tried google and still not been able to see close enough to figure this out
gblackwood01
Up until recently, I had an ODay Sprite. It was unusal as it was designed to be rigges either as a sloop (main sail and jib) or a cat configuration. The previous owner has a website of it and several other boats we owned which can be found here:
O'Day Sprite
PM me and I can provide you with what I have about Sprites.
- George
