Can someone tell me where is fuel pump located?7.4 mpi
Iaintslow
Gen 6 L29 7.4 mpi can someone tell me where the fuel pump located and how hard it is to replace it? I know it is inline electric one. Also anti siphon valve is it the one attached to the fuel tank 90deg or fitting that attached to that 90deg plug? I attached picture of the motor and gas tank.
thanks
Bt Doctur
the pump can be on either side of the front motor mount, need the engine serial number to be sure
alldodge
The pump is on the port side behind the motor mount. Might have a boost pump by the filter but unable to see the serial number.
Yes, the anrisiphon valve is on the 90 degree fitting
Iaintslow
Sorry guys, i attached serial number and 2 photos of the area there one from front under the pulley and other on the side, is it inside that black box?
Bt Doctur
That is the "cool fuel" unit and has the high pressure pump inside it. Remove the water hoses, remove the 2 lines from the fuel filter, remove the 2 shoulder nuts off the front motor mount, remove the cool fuel unit
