Can this CMC tilt cable be replaced?
DJ_Allatoona
I have a CMC power tilt on my Starcraft. The cable running out of the top (pictured below) has been pinched a few million times where it crosses the transom and it's damaged in one spot. I've fixed it for now with liquid electrical tape, but I can't seem to find JUST this cable. Is it replaceable?
The Force power
I'd say; you can open it up and see.
If there's terminals under the cover, I would use regular extension-cord cable 14/3 gauge or 14/2 whatever you need.
If no terminals; cut/splice a new section in under the cover & use wiring as above mentioned
tbetty
Did you contact CMC about a new cable. CMC Marine Products 800-654-3697, I found them to be extremely helpful recently with a wiring harness troubleshoot and replacement. Phil
DJ_Allatoona
Yeah, tried to call them. They're back in the office after the first of the year.
