Re: can u put a good prop on 1978 johnson 25 hp and if so where good place to buy it?
It either has the wrong prop or you measured wrong.Measure from center of the bore to the tip of one blade and double the result.
It came with a 9 1/4" X 11" (diameter X pitch. Options in 78 were 9 1/4 X 7,9 X 10 weedless and 9 X 9.
Do you know the dry weight of the boat . Does it have a soft or hard chine?
From the size of the boat it appears a 9 1/4 X 11 prop should work.
