Can you find the ignition key # from the motor's serial #?
99yam40
Re: Can you find the ignition key # from the motor's serial #?
no idea what you are sticking this key into, but normally you would look at the switch to see what key # is
robert graham
Check behind that little black rubber gromet/hex nut on your ignition swith for the key #'s....
seahorse5
If you cannot find a key number, then take your boat to a dealer as many have rings of keys to try out and can get the number that way.
lakensea
Also, if there is no key number, than it is most likely an aftermarket ignition switch as all outboard manufacturers have numbered keys. If it is an aftermarket switch, you may be able to have a hardware store/locksmith make a duplicate.
