Jasoniboat
- Jun 23, 2011
- 38
I have an 18ft Searay runabout. Based on a recommendation from West Marine, I purchased 303's Fabric/vinyl cleaner and Aerospace UV protectant to clean my vinyl engine cover ( see photo # 1799). I followed the instructions closely for both products and finished with the Aerospace Protectant and dried down the engine cover. The products worked well and returned the engine cover vinyl to near-white.
The boat stays in the garage with the Sunbrella cover off of the boat. About two weeks after applying the fabric/vinyl cleaner and following that with the 303 Aerospace protectant, I needed to take the boat in for some repair of exterior fiberglass near the front of the boat. For the trip to the repair facility, I snapped in my Sunbrella cover, which fits into the factory snaps around the boat and also fits snug over the white, vinyl engine cover, which is where a stain was discovered that ran across the stern, where the sunbrella cover comes into contact with the vinyl engine cover. The Sunbrella cover was snapped into place for 1.5 weeks, while the boat exterior fiberglass was being repaired.
I removed the Sunbrella cover 1.5 weeks later, when the repair was complete.
( see photos #1996 ? sunbrella cover, #1995 vinyl engine cover, #1994 ? stain on the vinyl engine cover when Sunbrella was removed.
I took a look at the sunbrella cover and the area of the cover that comes into contact with the vinyl engine cover (which was stained). I see a slight sheen on its underside of the Sunbrella fabric, where it came into contact with the vinyl engine cover.
My thought is that the ?sheen? on the Sunbrella fabric is from a combination of the Sunbrella vinyl cleaner and the Sunbrella UV protectant and that somehow having the Sunbrella cover tightly snapped over the engine cover, plus the sun, may have caused the stain.
Does anyone have any other thoughts ? The vinyl was completely white before I took it in for repair and the boat had not been used since. The Sunbrella cover was never unsnapped and the boat wasn?t used. ???
I am hesitant to use the Aerospace Protectant any more, as it appears it could cause staining if the Sunbrella cover interacts with the protectant.
Also, I had to scrub pretty aggressively to remove the stains. Does anyone know of a product that I can use to restore "sheen" to the vinyl where I had to scrub to remove the stain ? ??
Any feedback
Sincerely,
Jason West
Any feedback
Sincerely,
Jason West
