Can you recommend a kill switch for my boat
Bob_VT
Re: Can you recommend a kill switch for my boat
Yes, that will work. You can side mount the switch or dash mount it...... dealer's choice :) on where it should be. Usually I have always had them in a bass boat and other boats with outboards..... I really have never had one in an I/O.
Lrider
A 357 comes to mind
truckermatt
i am not sure what a 357 has to do with anything...
I just wanted some advice on a kill switch like the new boats come with so in case the driver goes overboard the boat will shut off and not run away.
Lrider
SOrry that was ment to be a JOKE what you posted before is the solution, it was my error in thinking you were going to do what Bob_VT was suggesting
Again I apologize profusely
jay_merrill
Yup, its fine. I have one in my boat. Its a universal switch, so it will work by closing to ground or by opening a circuit.
The PFD that I wear all of the time, has a a d-ring sewn into it for use with a kill switch lanyard, so its very easy to use. It will take you a little while to get used to being "tethered," but its not a big deal.
truckermatt
no problem at all.... But sometimes at some of the smaller lakes around here ( the ones that only let you go in one counter-clockwise direction, a runaway boat could be a very bad thing headed for the beach where families are swimming...)
But sometimes i worry about the bad things too much i guess.
Bob_VT
Matt if it will give you piece of mind then by all means do it. They are really fairly cheap ;)
