can you replace merc 120 engine block with plain gm 2.5
lab1484
is it possible to replace mercruiser 120 2.5 engine block with a plain ol' run of the mill GM 2.5 engine block without any major issues
D
DJ
Guest
Re: can you replace merc 120 engine block with plain gm 2.5
I doubt it.
It depends on where that GM 2.5 came from.
If it came from a GM vehicle post 1965, the answer is NO.
The GM 2.5 liter, there have been several. Only one was the 'inustrial/marine" version. Car engines need not apply. There are NO similar characteristics, other than displacement.
With that said, you can replace the GM 2.5 with a 3.0 very cheaply. They are everywhere. Rebuilt, new, etc.
lab1484
mercruiser is a 79 really hopeing around same year of gm block of would work. alot easier to find.
D
DJ
Guest
The 1979 GM (MerCruiser/OMC) has NO resemblence to automotive blocks, of that year range.
As stated, if you need a block, they are readily available at reasonable prices. Just NOT from the auto junkyard.
You will not find an AUTOMOTIVE GM block, of that vinatage to work.
A GM "marine" engine, of that vintage will. Be it MC or OMC.
lab1484
thanks alot, still looking for one
Nope,...2 Totally different motors...
The 2.5l automotive motor is the GM corporate motor, which is a 151cid motor of Pontiac heritage...
The 2.5l Marine/ Industrial GM motor is a 153cid motor of Chevy heritage....
