can you run on 1 cylinder ?
Status
Not open for further replies.
Leinenkugel#1
1987 force 85hp. I want to make sure the 2nd cylinder is working (middle one) can I pull the top and bottom plugs while the motor is running? or pull them before I start the motor? or NOT AT ALL? :redface: I plan on going to get a compression tester today but I live out town (40 miles) Like I mentioned before in a earlier post, the middle plug looks way to shinny on the firing side.
thanks
yohuallin
Re: can you run on 1 cylinder ?
mine is also a 87 85hp, and yes it does run on 1 cyl it doesnt last more than a minute but it does run..
JB
Yes. Start her up on muffs and, at idle, disable (CAREFULLY!!) each spark plug in turn.
Doing that to a dead cylinder will cause no change. Doing it to a cylinder making power will cause the idle speed to drop or stall the engine.
Standard way to detect a dead cylinder.
Status
