hi i havent gotten my block back from the machine shop so i just asking questions ahead of time
i read online you test the timing when engine is running but if its out of wack it might damage things.. and i having new pistons put in so dont want that
now on my 115 chrysler engine i set the timing of the engine with the engine off and throttle forward and you pressed on the belt and the cdi box when you pressed on the belt causes it to spark the coil (but didnt have it hooked up just to a mulit meter so id get 12 volts on my multimeter and it was set like 32 degrees or something it lined up with the sticker on the fly wheel... but how do you guys do it with this engine... is there any good videos also to watch so i can get a grasp on it before i get it back and set it up
so i wanted to know if you can do the same like with the chrysler engine with this engine too something similar. like turning the flywheell a little
