I spliced one a couple of years ago. It worked fine.
I cut the wire pairs (about 5 of them as I recall) to different lengths so the butt connectors wouldn't all sit in the same spot. I shrink wrapped each pair, too. Tedious operation but it worked.
My .02
yes no problem mine was only co ax but if you have a temp sensor it will be more wires ..
Yeah has temp too--I'll guessing about 3hrs of work--it will give me something to do![]()
Not unless the splice is buried somewhere. And make sure you have good wire insertion into the butts before you crimp. Little tiny 22GA wire is a PITA to work with, so take your time...
