Cannot find correct water pump for my Johnson 9.9hp outboard
mjbuck
I'm in need of a water pump replacement kit for my 2007 Johnson 9.9hp outboard. I ordered what iboats.com said was the correct kit, but it is entirely the incorrect replacement. I have looking on the internet for an hour or more and each kit I find shows it will work with my motor, but they are the same kit as I got from iboats.com, which is definitely the wrong one. I used my model number to find the kit I need, but obviously there is a mix-up. The top kit in the picture is the kit I took off, the bottom kit is the one I was sent. It is obvious these are two different items. Can anyone suggest anything?
mjbuck
The model number is J10TBL4SD. That is directly from the engine plate. The manufacture date on the same label is 2006, so I assumed it was a 2007, but I realize now I was wrong on the year. But, I did check 2006 and 2007 water pump kits for this model and still had difficulty finding what I needed. What I believe happened is the model number might be incorrect on my engine plate, because I just now found a kit that matches up identically with the one I removed. I found it on boats.net and I believe it is the right one with the right accessories to go with it. When I couldn't find what I needed under 2006 and 2007, I started to study other model numbers and found (what I believe) is the right kit. Thank you for your help, but I think I just now got it solved. Could it be possible the model number on my engine plate is incorrect? Like I said, I researched other model numbers from the same year (2006/2007) and I found diagrams that show the exact parts I need. I do know for sure the parts listed for my model number are not the same parts I need to finish this. Just as the photo shows two completely different items, but yet every web site or supplier says it is the right one. I'm guessing there is a mix-up somewhere and I think I solved it. Thanks again.
????????----Fairly easy ----Your motor is a 4 stroke built by Suzuki I believe.
sumocomputers
I couldn't find a J10TBL4SD exactly.
I think your engine plate is correct, but maybe the last number is not legible for some reason? I see a 2006 J10TBL4SDE which is listed as a 10HP on the BRP catalog, a 9.9HP elsewhere.
Water pump parts seems to match up with what you have in the top part of your photo.
BRP lists 2 models of the 9.9 for 2007---------One is the 2 stroke that has used the same water pump since 1974.--The other is the SUZUKI built 4 stroke with of course a totally different pump and impeller.
sumocomputers
Sorry for the incorrect info. I was using The EPC at epc.brp.com, and could not find the OP's exact model. Weird that they don't list the Suzuki made 4 stroke model he has...
