Cannot match trim motor. Clearly I am missing something. Help please!
Mikecaldo
I am trying without any luck to replace the trim motor on my 5.0 GL PEFS, SX-M outdrive. The motor burned up, so the outdrive won't go up or down. I've searched high and low, but everything I find that is supposed to be compatible won't fit. The centers on the mounting bolts are always either too narrow or too wide. Even called the Volvo Penta store. They gave me part number 3858071, which has 2.5" mounting bolt centers. (original number on the pump was 3860879). Ordered a second motor that was supposed to fit with 2.3" centered mounting bolts. You guessed it, too narrow. I'm not really sure what to do.... I can't seem to find anything that will fit.
Any guidance is appreciated. Here's what I know in bullet format:
Engine: 5.0 GL PEFS, Serial Number 4012044083
Original number on the pump motor: 3860879.
Model year is 2000.
I've tried to use part # 3861575 and #3586765... neither work.
Volvo store gave me # 3858071, but it says 2.5 inch centers, which would be too big.
It can't be this hard... any help is appreciated
jerryjerry05
If you can't find it here?
trymastertechmarine.
They have a good selection and can help when others can't
