Cannot remove gearbox flat screws on Johnson 1972 4HP outboard
mircearstan
Newbie here, profuse apologies for this request but after 1 week of struggle I'm a bit desperate...
Trying to service the water pump on a 1972 Johnson 4HP outboard and everything went fine until I had to remove to flat screws on top of the gearbox to reach the water pump (see photo). I tried *everything*, regular flat screwdriver, power screwdriver, impact driver, the screws just won't budge :( The main problem is the "flat" aspect of the screws, there is really nothing I can figure out to do to keep the tip from slipping when I apply force. This should be a common issue for these lower units so I hope someone has a ready smart solution that I didn't think of.
In any case, if I get these off I'll make sure to use a different kind screws when I put it back. Thanks a lot!!!
There are various ways.-----Grind the head off.----Remove pump housing and impeller.-----Heat the housing and use vice grip to remove screws.----Impact screwdriver can also be used.-----I would grind the heads off.
Crosbyman
1/4 inch impact screw /nut driver try deepening the slot a bit with a hacksaw blade (not to much) before impacting
try to screw in a bolt just a tad to see if the thing moves forward .... then unscrew it
try shock freezing the bolt head 10-15 seconds with keyboard air blaster can (dollar store) held upside down
very important.... use proper sized flat blade on any screw/bolt head
but....grinding the head off will allow you to soak the threads with wd-40 or similar lubricants (Dupont snowblower silicone spray does wonders)
mircearstan
I was hoping for some magic but I guess good old elbow grease will do. I am still surprised that with so many of these motors around there are still such basic issues that linger. Anything other than a flat screw would have likely not caused this issue...
oldboat1
Big dog screwdriver (biggest one in your toolbox or your neighbor's). Visegrip clamped near the blade. Bear down hard vertically and use the vise grip as a lever to turn counterclockwise.
Back in the day the folks had to work hard to earn the money to buy a new outboard motor.-------They were expensive compared to today !!----Folks knew that you had to look at the impeller every 5 years or so.-----Today folks are much different.-----Never see the hood up at the gas station to check the oil !!----Run the outboard motor till it goes --" BOOM "
werewolf
if the screws dont turn i use a small plumbers torch and heat the screw head and soak it with gm heat valve spray, that stuff will loosen bad rusted parts , small amount of heat and it pulls the spray in like a vaccum
Heat the housing. where screw threads are.----No need to heat the screw.
