Hey all,
Ok, so I have an 18' Coleman, made of kevlar plastic (very durable). I already have a trolling motor and mount setup, which works great...there is 1 tiny problem though (which I'll get to). Now I also just picked up a 4HP Evinrude 4006e (1974 I think?). I have custom fabricated a bracket so it mounts up to the back of my canoe (which is non-sport, aka, pointed on both ends). That's all fine and dandy so far.
Now when I have myself and another in the canoe, the canoe has the perfect trim. What I'm after is a few answers to some questions. I have a 6 Gallon gas tank and a deep cycle that probably weight 60-80lbs (I can run the trolling motor 12hours continuous).
1. When I'm solo, what would be my best weight distribution? It would be easier to have the batter up from probably than extend the fuel line all the way to the front?
2. Can a motor have enough trim to plain the canoe out when solo or is that a bad idea? My bracket is adjustable upto 30 degrees (plus the motor has adjustment)
3. On a real boat, you can get trim boards, anything similar for a canoe? Or would it be worth me fabbing something?
4. On the motor I just got, 24:1 is the right mixture? so I 6 gallon tank should take about 32oz (950ml) of oil?
5. Does an incorrect fuel/oil mixture affect performance? I noticed after MY mix (after buying) that I wasn't getting the same power, and I know it's 90/90 compression, new plugs and wires. I believe I did 50:1 or 75:1 (what was on the bottle), but found out through these forums it should have WAY more oil in it. Can anyone verify this one?
6. Anyone know a good place to get hydrofoil outriggers (ama)? just the pontoon, not the whole device.
I'll have to take some pictures when it's daylight so you can see what I'm talking about.
