i have seen a few similar questions but not sure if this is the same problem. i have a 79 mercruiser 898 just put a motor in it i took it out for the first time tonight and when i put the boat in it got stuck in reverse i turned the motor off and it went right in to neutral and it does the same thing in forward.but when the boat is on muffs it goes right into neutral just like it should any help in the right direction would be very helpful thanks ben
