cant find correct drive damper plate for my 190 DP
larryb1963
I have a 1996 volvo penta 5.8 (ford) fuel injection with the 190 DP outdrive . I can not find a part number for the correct drive plate damper ? I did find a number but does not cross to anything (A5-010522-ford ) I see one used on ebay for $375.00 (ridiculous) I posted a picture hope someone can help me here .s-l140.jpg
Bt Doctur
check the number of splines and see if a Ford clutch has the same number of splines
Most engines use a modified clutch plate without the fiber pads
The VP drive uses a 26 tooth 1-5/32 spline ,(like a GM truck)
Any drive plate with the ford clutch pattern will work. Even the one from my 1988 290DP.
What is wrong with yours that a wire brush and paint would not cure?
They are about $120 from most drive line shops
