Re: Can't find enging serial number or data plate
Yeah, I continue to struggle with identifying the engine. I looked all over it with a flashlight and a mirror trying to find a data plate on it. I've had two I/O boats before this- one new, so it was easy, and the other a Cobalt, and I didn't do much besides replacing the blower and working on the tilt wiring. So I don't know much about what I'm doing, and frequently don't know what to ask to get the answer that will help me.
Don- thanks for explaining the SBC term- I hadn't heard it before either.
I bookmarked the MORTEC website, and I'll check casting numbers on the block after the rain lets up tomorrow or Tuesday- thanks!
Anytime I try to find parts, they want to look it up by engine specs, and that's where I put on a blank look because I don't know what to tell them. I already replaced the water filter, and the oil & oil filter. It has NGK BF6RS plugs in it, so I know I can use those or the MR43T, but I would like to replace the distributor cap and points as well, and that requires info I don't have, or I don't understand.
Bt Doctur - Why is the steel fuel line preferable? I've used rubber lines on , cars, trucks, ATVs, street and racing motorcycles, but I don't have the marine experience to understand why a metal line would be critical or more important in this application.
Thanks again for everyone's help- I did a compression check on it today- highest was 130 (left rear), lowest (front right) was 110, and all the other cylinders were in the 120 range. The boat dies when shifting into gear, so I suspect a carb rebuild may be in order, but I want to do the electrics first- probably because I know how to do those things.
