Can't find info on my boat manufacturer
Thuggin4Life
I have a welded 12' western boat made by shasta aluminum products inc. and i can't find any ifo about this boat or the manufacturer. its a w12 model. I was trying to get ahold of the company and see if i could find the exact specs on the wood the cut for the benches since the ones i am replacing are not in great shape to use for a template. Google wouldn't pull up any info on them or the boat i have. Did they go out of buissness or something? is there any info out there on this? anything helps.
ziggy
Re: Can't find info on my boat manufacturer
good luck in your quest man. be aware that for some boats there just ain't any info available for them. i've got one too. a trisonic. i've researched every which way to no avail. i just don't find anything tech. spec. wise on it...
Willyclay
The link below will get you to the page for Shasta Aluminum Products, Inc. in the database maintained by USCG for the Manufacturers Indentification Code (MIC). Yes, they are out of business but their assets were acquired by another builder (ENY) and you may be able to find someone who can help you. I did with my boat and the people were very helpful. Good luck!
http://www.uscgboating.org/recalls/mic_detail.aspx?id=SAZ
EDIT: ENY is OOB also but there are names, addresses and telephone numbers in both MIC files that could possibly help you. That's what I used to make my contacts.
