Need help trying to locate switch for livewells on a 93 astro 18 foot fish and ski all that I see is the aerator and bilge pump switches any help on this is greatly appreciated
Re: cant find livewell switch on my 1993 astro just bought
Thanks for the tip baseman and super mariner I thought the aerator switch was for the livewells just wasn't sure cause when I turned on the switch nothing happened guess I got bad wiring or bad pump
Or a bad fuse. If you have a test light or voltmeter and know how to use it, check for power at the INPUT (LINE) side of the switch. If no power there, work back to the source which is typically the fuse panel. If you have 12 volts at the switch, turn the switch on and check the OUTPUT (LOAD) side. No power there the switch is bad (highly unlikely). If 12 votls is present check for power at the pump. If 12v is present the pump is bad. If not, the wiring between the switch and the pump is bad.
