Re: Can't find the right replacement prop? (71 merc 135)
i agree the Solas props have a good reputation.
If you are changing props this may be the time to fine tune your application.
If you can get us your present performance,wot rpm and speed also your gear ratio.
You can confirm the diameter of yours by measuring from the center of the bore to the tip of a blade and double it.
Diameter is a secondary consideration you may note that as pitch goes up generally diameter goes down,a 4 blade is usually smaller diameter than a 3 bld.
