cant fix that prop
road.ripper
my prop is a model 48-65748 A1 -17p it has a 15 spline hub .
aluminum 3 blade on a 1970 -65 hp 650 merc .
can some one please explain all these numbers, i know 17p is pitch but what the heck is the rest of them mean ? im looking for a used prop and
i dont know the diameter as mine is missing alot off each blade.
what else will fit ? etc.
any help pls thks
Road
Re: cant fix that prop
Ayuh,... It's just a Part #... the 48- tells Me, it's a Merc. #...
For the 15 spline Merc props, they come in 2 flavors...
The 1s for the smaller/ older outboards with the 4" gear case...
Which'll have 4" prop barrel/ bodies...
And,...
The 1s for the Large gear case outboards,+ the I/Os with the 4, 1/2" gear cases,...
Which'll of course have 4,1/2" prop barrel/ bodies...
Generally speaking, the smaller 1s, like you need, the diameter is in the 12" to 13"+ range....
The larger 1s usually run from 14" to 15"+ range...
A Larger prop mounted on the smaller gear case will rub against the case....
A smaller prop on a larger gear case will Ventilate,... Very Badly....
But, Either size will mount on Either propshaft...
Hope that Helps,....;)
Silvertip
It is a 13 inch diameter three blade with 17 inches of pitch. Part numbers are a way for the manufacturer to build and identify parts. The number is just a number. In the manufacturing business any product that has more than one part is called an assembly. Each part in that assembly has a part number as well. Only identical parts will have the same part part number. Part numbers are used to order replacement parts from that manufacturer. Aftermarket parts suppliers would apply their own part number. It took nothing more than a 5 second Yahoo search to turn up what diameter this prop was. Now to order a new one, you no longer need to go to Merc. Go right here on IBoats, enter your engine make year and HP and you will be presented with a variety of props to choose from -- all specifically for your engine.
http://boatpropellers.iboats.com/
Fun Times
Item Supersession Chain: Here is a list of all the part numbers mercury has used over the years for this part# 65748A1 you have posted.
Row Class Part Number SS Level Disp Description
1 48 77344A45 00 ACT BLMX 13 1/4R17
2 48 65748A1 01 SS BLMX 13R17
3 48 37900A3 02 SS BLMX 12 1/2R15
4 48 31074A3 03 SS PROPELLER ASSY
5 48 29660A3 04 SS PROPELLER ASSY
6 48 29660A2 05 SS PROPELLER ASSY
7 48 29660A1 06 SS PROPELLER ASSY
8 48 31074A2 07 SS PROPELLER ASSY
9 48 37898A4 08 SS PROPELLER ASSY
10 48 29662A4 09 SS PROPELLER ASSY
11 48 31076A4 010 SS PROPELLER ASSY
12 48 37900A2 011 SS PROPELLER ASSY
13 48 32264A3 012 SS PROPELLER ASSY
14 48 31458A3 013 SS PROPELLER ASSY
15 48 30390A1 014 SS PROPELLER ASSY
16 48 31082A1 015 SS PROPELLER ASSY
17 48 37902A3 016 SS PROPELLER
18 48 31072A3 017 SS PROPELLER ASSY
19 48 29658A3 018 SS PROPELLER ASSY
20 48 29658A2 019 SS PROPELLER ASSY
21 48 29658A1 020 SS PROPELLER ASSY
22 48 31072A2 021 SS PROPELLER ASSY
23 48 37900A4 022 SS PROPELLER ASSY
24 48 31074A4 023 SS PROPELLER ASSY
25 48 29660A4 024 SS PROPELLER ASSY
26 48 37902A2 025 SS PROPELLER ASSY
27 48 77344A40 01 SS BLKMAX 13.25X17RH
28 48 77344A4 02 SS PROPELLER
29 48 65022A4 03 SS PROPELLER ASSY
30 48 53900A4 04 SS PROPELLER ASSY
31 48 65024A1 05 SS PROPELLER ASSY
32 48 53896A3 06 SS PROPELLER ASSY
33 48 65748A4 07 SS PROPELLER ASSY
34 48 32264A4 08 SS PROPELLER ASSY
35 48 31458A4 09 SS PROPELLER ASSY
36 48 77344ARA 01 SS BLMX 13 1/4R17
Here is some updated info from mercruiser about your prop with the part number you posted, You could still order it from any Mercury Dealer, Or you could more then likely find one online someplace, For example iboats i'm sure has one.
65748A1 is Superseded to 77344A45
Class:48
Supersession
Item Number: 77344A45
Status: Active
Weight: 7.563 lbs
Description: BLMX 13 1/4, Right hand, X,17 pitch.
Package Quantity: 1
MSRP: $165.39 Price
road.ripper
perfect ,thanks guys, now i can understand it
