I have read every post on this site on tips to get the HARD carbon off my pistons. I have the pistons out of the motor since I am doing a rebuild. There is a hard carbon buildup of about 1/32" covering at least 80% of the top. I have tried carb cleaner. Engine tuner. and soaked overnight in both to no avail. A wire wheel is the only thing that takes it off...but it takes off that factory piston coating as well. I am sure that coating is there for a reason. I have a 97 looper. Anyone have anything else? Too many snake oil suggestions so far. engine tuner, carb cleaner, sea foam...none of that stuff works. surely there is some chemical (or non-damaging mechanical process) that will remove this stuff. Can I just leave it alone?
