Cant get flywheel off!
wku403
i need some suggestions on how to get the flywheel off my 89 bayliner capri 85 hp. The flywheel bolt came off fine, ive tried an impact wrench and a puller. Ive let pb blaster sit on it for two days and ive even made a wedge and hit it with a hammer to try and pop it off....no luck....i need to change the stator and cannot do so without getting this flywheel off. Please help im landlocked for the summer until i can get the stator changed. THANKS
jerryjerry05
Re: Cant get flywheel off!
Get a big 3 jaw puller.Put the nut back on 1/2 way. Use an impact tighten till you think it can't take it any more and put an old socket on the screw (or not) and use a 3# hammer and hit the socket.It should pop loose. Good luck Jerry
