Can't get Gear Case Off
FloronGlenn
1971 Evinrude, 50 HP, Hydro Electric Shift. I have removed one bolt from the trim tab and one just forward of the trim tab. I have removed the four bolts that hold the gear case on. There are no others. Case has dropped down about 1/16 of an inch on the forward part, still tight on the aft. Been tapping with a rubber mallet to no avail. Tried heat, didn't help. Any advice?
OBJ
Re: Can't get Gear Case Off
Glenn....look up in the cavity under the trim tab. There is another bolt there. 1/2inch head.
