Hi,
I'm trying to replace the lower unit on an Alpha 1 Gen 2.
Seemed to come off OK tho took a bit of shaking. Fresh water and was off last year for water pump.
For the most part a little wiggling for got the lower within an inch of mating with the upper. It seems to be hung up on the splines but no amount of twisting or shaking seems to get it seated.
Tried this maybe a dozen times with no luck.
Odd thing is when I did the water pump it went right back on.
The drive is in fwd and the shaft bottoms out just before the shifter parts meet.
On a side note it would seem a good idea to replace the shaft seals (2 orings?) but how to do this when they are wedged up in the core of the drive?
Also when the boat is in fwd the upper end of the shift is not quite straight front to back. Does this mean I need to adjust the cable (hopefully from upper end) or is it normal to be offset slightly?
Thanks
Nick..
Thanks
Nick..
