I still say he needs to check for water in the hull and to try re-distributing weight before he does anything else.
I think you people are giving him bad advice about replacing the Force engine. That hull with that engine will only do mid 30s. If he is doing 20 MPH and pushing a lot of water with the bow high, you can not blame the engine. However, it would not hurt to perform a compression test to make sure the engine is OK internally.
