I am trying to take my outdrive off to inspect everything and I cant get it to come loose. Shift is in forward, trim cylinders removed, 6 bolts removed and I just cant get it to budge.
I tried sticking a piece of 2x4 in-between the outdrive and bottom of bellhousing to drop it and break it loose but nothing. Ive beat the hell out of it with a hammer and nothing.
I am reading this in the Seloc manual - "Another method is to remove the U-Joint bearing retainer as detailed in the Upper Unit Disassembly & Assembly section; the stern drive can then be removed, leaving the frozen shaft in the bell housing." Id like to see if there is anything else I can do before this. Any help would be much appreciated. Thanks
Merc alpha1gen2. 2003. 220hrs. Not sure when the last time any real maintenance has been done.
