Can't get RPMs
doggunit
My '63 Johnson 28 hp has good compression, recent carb overhaul, new ignition, but isn't delivering the horses. Symptoms include hesitation, slow revving, no increase in rpms from 3/4 to WOT, seems to like lean mixtures (1/2 turn from closed low speed, about 1/3 turn high speed), bottom plug is usually wet, unburned fuel/oil leaks from gearcase weephole after every run. Does this sound like a retarded timing or spark advance problem? If not, what to look for?
fireman57
Re: Can't get RPMs
If your bottom plug is that wet then I would suspect loss of spark to that plug. Check the coils for cracks in the insulation. This part is pretty inexpensive so you may need to replace it.
BR_Dumz
Re: Can't get RPMs
i had an old sea king that i stored in the barn one winter and the mice built a nest under the cover....pluged air inlet....maybe that could be problem
REELSPORT
Re: Can't get RPMs
try and do a link and synk could be the problem
doggunit
Re: Can't get RPMs
do you mean throttle-timing linkage? Also, I have found burn holes in the safety switch lead wire to cut-out, temporarily pulled this lead off.
