I took off the belt to service the impeller pump a few days ago when it was 70 degrees out.
Now that the temp has dropped to the 50s, I cant get it back on.
I checked the belt diagram multiple times so I know I'm putting on the right way.
The idle/tension pulley is way too tight.
So I think there are a couple of options:
1. Try to heat the belt up before putting it back on. Should I use a tub of hot water? Blow dryer? Butane torch?
2. Try to adjust the tension of the idle/tension pulley so that it will move further out of the way so it's easier to get the belt back on. However I don't know how to do this or if it's even possible. I showed pictures of the tension pulley below. Is there a way to adjust it so that it rotates further and provides less tension so I can get it back on?
