Have a 1989 Yam 70 and I am having problems with the T&T. It was having trouble lifting and lowering the motor so I attempted to top up the fluid.
I know the most common procedure is to loosen the manual release screw and then lift the motor and lower it by hand 4 times so as to not create foam.
Unfortunately I cannot budge the motor when I attempt to lift it, even with the screw almost all the way out.
Any help would be appreciated.
