michaud500
- Sep 3, 2011
- 91
I have a 1976 50hp #2629264. I reoved the lower unit to replace the impeller and decided to try and remove the entire pump to see how things work. When I got to the lower pump housing I could not budge it. I tried a piece of wood and a mallet nect to the exhaust port and gently but firmly tapped the wood. It moved a little bit, but I tapped it back. I tried moving the front bot there is no way to get underneath it that I can figure. In the manual it said something about a screw hole but I see nothing of the such. I would like to get it off but will I need to replace the pump entirely with a repair kit after having to force the part off? The parts are old the impeller was trash and the seals are old. Any and all advice is welcome!
One more thing does someone have a parts # list with pics so I can get the correct parts?
Thanks
Thanks
