Can't remove steering cable from power steering assembly
JASinIL2006
Hi, I am in the process of removing my Alpha One Gen II transom assembly. I am working on removing the power steering assembly, but I cannot get the steering cable out of the cylinder. I've loosened the nut and even banged against it to pull it out of the cylinder, but it seems stuck. I must be doing something wrong... any ideas. This is what it looks like.
Is there something else I should be loosening/disconnecting to get the cable out of there? The service manual just says to "disconnect the steering cable", but doesn't say how. What am I missing?
Thanks,
Jim
jackd1023
Re: Can't remove steering cable from power steering assembly
did you pull the large pin? usually has cotter pin on the bottom
jackd1023
I dont see it in the picture but there is one on the right hand side
JASinIL2006
This picture shows the two pins... I removed the longer pin on the left... am I supposed to remove the shorter pin on the right as well?
jackd1023
Looks like you removed the engine mount bolts. I see both of the stainless pins on the power steering rack itself
JASinIL2006
Yes, the engine has been pulled and I'm now trying to remove the transom assembly to deal with a rotten transom. The picture in post #4 above shows the power steering unit before I removed the clevis pin on the left. Imagine the left pin has been removed (as it was, after the picture was taken), and the right pin is still in. Am I supposed to remove the right pin, too?
Sorry I wasn't clearer...
Thanks,
Jim
Ayuh,.... That's the pin holdin' the cable, Yes,....
The other pin is in the tiller arm...
JASinIL2006
I figured I must have done something wrong.... but I didn't want to just start disassembling things. The service manual wasn't terribly clear about which pins to pull...
Thanks!
Jim
