Well, it's a long sad story, but the short version is the block froze> got a new long block> lots of screw-ups all around> now it runs (sort-of) but nobody wants to work on it due to the history. I'm not an engine guy, but I'm trying to get up to speed. Bought a timing light and vacuum gauge and have been tinkering.
Problem is at idle/low speed. Really rough, hard to keep it running. If I set the curb idle high enough to make it smooth it shifts really hard and leave a wake all the time.
Watched some youtube and thought step one was to get the timing set, then step two, on to the idle screws on the front sides of the carb. Have had some luck with step two but have been having trouble getting a vacuum reading. Haven't found a connection that shows any vacuum.
Thing is, the low speed performance overall is somewhat erratic. Once warmed up it will be really rough, and then other times not too bad. At higher speeds seems to run well.
Never had a ny issues like this prior to the engine work. Keep thinking there is a sensor somewhere with a loose connector or something, but I don't know what I don't know.
